MiskinDriver
Been saying for a while that I wanted to try non tidal Thames, so took the plunge and got the survey for a BSC. Needs some work, though not too much, so arranged to go to Sunbury and have the work done there.
Sorted tides for Tower and Richmond, decided the best day - today. Checked everything on boat and did a couple of quick trips last week to make sure all well.
Set off today and within 2 minutes the overheat alarm goes off. Assume its rubbish on the raw water intake (not an unusual experience) and throw boat around a bit (to consternation of passenger), turn to face the opposite way, all the things that usually work - but to no avail. Tie up to a rubbish barge (one of the moored ones - not attached to tug, obviously) and wait but still no joy.
Limp back into South Dock with minimum use of engine, which means I clip the lock side a bit harder than I meant to (because by now the tide is running full bore) and eventually back to mooring. Spend rest of day arranging engineers, lift out - you name it.
Why do we do it ..............
