RobWales
Hi all,
I suspect that the diesel fuel tank might be leaking (yet to be proven)on my Fairline sprint mobo!
The tank which is aluminium and full width of the boat sits within a dedicated compartment and has approx 1/2 inch clearance all around to each bulkhead, I have noticed diesel sitting in this void space and cannot see any leak paths from the only connections which are on top...i.e filler,supply,return,vent and level sender.
I aim to fully investigate the causes at the weekend...?
However as a pre thought to a remedy, removal of the tank is going to cause me to have to cut the pre moulded deck sections away at each end, as it seems the tank was fitted prior to the moulded deck being bonded in place this I would prefer not to have to do!
So a bit of lateral thinking here and please chip in with suggestions...
What if I were to drain the tank and the void space and then fill the void space with a medium of sorts...i.e closed cell polyurethane foam injected in? or some form of resin poured in....in the hope that this would then seal from the outside?
The total amount of "medium" required would not be a vast amount to fill the void space so I'm certainly not worried that its going to add weight!
And if the said medium is filled up to the top face of the outside of tank then can it leak any further above this point?
Maybe I'm being deluded but what does the panel think?
Thanks in advacnce.
Thanks in advacnce.
