I think you should redirect your question to themultihull.com
As a rough guide since Prouts are not known known for rapid acceleration
there's no reason why a Hydrovane shouldn't work.
I know the designer likes a good distance 'tween the boats rudder and
the vanes rudder which could be awkward if mounted
on one of the Prout hulls, but maybe you could mount it
on the aft beam.
I have considered it myself on a Kelsall cruising tri and occasionally
they appear secondhand. Have you discussed it with the vane's designer?
If you want a directly operated auxilliary rudder there's also the
"Autohelm" by Scanmar, or a secondhand Mustafa.
If you don't mind a pendulum servo then there are many more choices.
There is an ARC survey of wind vanes among other gear in the YW website
and the current isssue.
