bobnewbury
Have just been away for two weeks of torrential rain & high winds, so no change there.
Observed an interesting little phenomenon in the heads this year. We have a lavac installed on the starboard side with the top of the bowl just about on the waterline. I plumbed in a holding tank with a fiendishly complicated set of diverters and loops last year and it worked perfectly, much to my surprise.
This year, however, we ended up being starboard side to pontoons in a heavy blow on several occasions. Under these conditions the bowl kept filling. On close observation (the joys of boating) it appears that each time the boat rolls to starboard a small amount of water enters the bowl from the inlet pipe.
The inlet seacock is on the port side about 70 cm below the waterline. As it's a Lavac I decided that I couldn't use an anti-siphon loop in the inlet, but I fed it through a loop that reached about 1 M above the waterline at its highest point (highest I could get).
What I suspect is happening is that the wind induced water pressure on the port side is pushing water up the inlet pipe and the rocking of the boat is sufficient to slosh a small amount over the top of the loop each time.
What confuses me though, is why doesn't the bowl overflow, even if this has been left to happen overnight? If I pump out the bowl with the lid up then it starts to fill with about a cupfull every 5 minutes, but it still never overflows.
Any ideas?
Any ideas?
