Cardo
So...
Following the palaver we had back in the summer, we're now in Corfu, hauled out and ready to be worked on.
My plan is to fix up the steering so it uses linkages to turn the rudders from a ram mounted inside the transom. Our current hydraulic "helms" push 50cl fluid per revolution.
I'm looking at one of these as a ram:
http://www.vetus-shop.com/vetus-hydraulic-steering-cylinder-mtc72-10mm-tubing-p-173.html
The dimensions all look right for what we're doing. I guess the question, apart from the obvious general suitability, is will this take the forces from the rudders ok? I don't know the exact dimensions of the rudders, but the boat is 10.5m and we don't really go much above 6 knots tops. Though, I will say the rudders are probably on the larger side for the size of boat.
This ram would give us approx 3 turns lock to lock, which is what we currently have, and seems to be a suitable setup.
Once we've returned to the UK and have some more spending cash, I'm hoping to overhaul the system further, replacing the helm pumps with probably these:
http://www.vetus-shop.com/vetus-hydraulic-steering-pump-htp42-black-10mm-with-valves-p-160.html
and replace the current autopilot with a hydraulic autopilot. We'd end up with 3.5 turns lock to lock, which again would be fine.
Any advice, as always, very much appreciated.
