howardclark
Got a Kobelt reversing pump. I think I may have had a problem for several years but not used the autopilot enough to see it.
System requires a 30amp fuse. That will blow quite quickly. A 40 amp fuse will last 30mins or so which is normally all I need .
I looked at the supply with a clamp on ammeter and could see the general current was low but with an occasional spike- presumably as the relays open and close.
decided to go further and put in a 50amp fuse! Was OK for 4 hours in a flat sea then blew! slow blow fuses seem to make no difference.
Think its time I sorted this- don’t really want to change the pump which involves a lot of extra work. Do the electrical/electronic experts on the forum think I am just lacking spike suppression or is this more serious? can I add a suppression circuit ? How can I analyse the problem further?
