SolentSnowgoose
I am looking to replace the Genoa on my Prout Snowgoose Cat... its a largeish sail and quite a low aspect ratio with the mast set well back.
From everything I had read I was pretty keen on a Radial Hydranet ( Dynema reinforced ) sail on the basis that it would hold its shape better under load ( Cat's don't heel so gust loads are high )
I discussed this with a well respected sail-maker and he pretty much talked me out of it and recommended a good quality Dacron Cross cut on the basis that we often beat to windward with the sail well furled ( our best set-up for beating in strong wind is well furled genoa and staysail) and that the Hydranet cloth would permanently distort if the sail was used hard when furled
I respect his knowledge but was a bit surprised given that the whole idea of the Dynema reinforcing is to reduce stretch
Would appreciate comments from others particularly those who beat with 2/3 - 3/4 Genoa rolled away or have experience with Hydranet Radial Genoas.
We were also considering "roller batten cars" on the end of the fully battened main to enable the sail to come down easier ..but again we were talked out of this in favor of either a tideway track or else basic slugs .
Again input appreciated.
