Hybrid halyards: thin dyneema + cheap tail
gregcope
21 Aug 2004
Anyone tried or seen Hybrid halyards consisting of a thin part spliced to a cheaper/thicker tail (for hauling/winching/clutches)?
For example you could have a 6 or 8mm 12 strand Dyneema standing part that did tack to deck spliced to a similar length of cheaper, thicker (12mm?) double braid for the run to the clutch.
Bar the faff of making one; what would the issues be bar not being able to end to end it?
I know you can just remove the cover from a 12mm dyneema doubl braid, but they can be quite expensive and that seems a good waste!
I need a new topping lift / spare so might make one as a lockdown project!
I think most people would want the same dyneema right through the halyard. yes I understand the clutch grip becomes a problem. I have a clutch for main halyard but it does slip so I simply add a horn cleat down the line from the clutch to provide really positive cleating. No I don't love clutches very much. This option might appeal to you.
Or alternatively take the outer from a 12mm rope section and feed it over the dyneema at the critical area and sew it through occasionally to keep it in place. ol'will
You can end for end, you just chop the splice out and make a new one at the other end. But you will find the existing hybrid last a long time anyway - so the need to end for end is reduced.
Jonathan
there are a few problems I am trying to address;
  1. Cost of decent Dyneema; half of which is wasted in the tail that is just used to hoist
  2. Size; Most people want a thicker tail for hand comfort when hauling in ie around 12mm but this is usually way over spec for most yachts
  3. As @William_H mentions Clutch grip can be an issue
@Neeves I now add a short piece of dyneema sheathing to high wear areas like mast sheeves. I would expect my lines to last a very long time ...
I do the same, dyneema hollow tape (obtainable from many rope makers) 'sweated' over a slightly smaller rope for areas of wear (sheets that rub on life lines, snubbers), I tried splicing but it was too much like hard work - I now sew. If your sheaves wear your halyards I might look at the sheaves and sheave slot - there really should not be wear. Dyneema is very abrasion resisitant.
Jonathan
Is the purpose of this for absolute performance (racing/extreme load) or for replacing wire halyards?
If not, why bother with a tail etc.? My preferred supplier of Liros dyneema reel ends sells for around £2/£3 per m, depending on diameter.
Unless you’re dead set on paying RRP, I’d just replace with polyester (or vectran) covered cruise/racing dyneema straight-through from eBay (many of the boat jumble suppliers have set up shop there now, what with C-19).
Over this winter I’ve slowly collected top-drawer dyneema (Liros XTR/Magic etc.) for all halyards and control lines on our 42’ and reckon I’ve spent <£500 in total, with lengths to spare. That’s all lines!
Dyneema = expensive just isn’t my experience, if you know where to look. But sorry if I’ve misunderstood the rationale in this case?!
@dankilb You have a good point. At those prices there is no point.
I too share you bargain hunting. Never paid RRP, but find 12mm in the lengths needed for a main halyard hard to find. YMMV.
Best bet for the longer lengths is just to ask. My supplier gets reel ends from the manufacturer - after they've run off the 200m reels for the retailers. That means a 'reel end' can theoretically be up to 199m! I gather than shorter lengths sell better, so he often chops up the longer lengths (unless he has a potential customer in mind, that is).
We've got a 17m mast (I think) and buy halyards over length, so I've sourced up to 45+m recently.
PM me and I can share their details with you. Rather not advertise my 'honey hole' too widely! ;)
