Outinthedinghy
Hello. I've recently bought a boat with a Lister LPW2 MGR with a Hurth 50 reduction gearbox. 1990 build year. All is clean and working well except that the output shaft bearing on the gearbox sounds like its dry. squeaks a bit when in gear or when turning the prop in neutral. The gearbox itself uses ATF and shows at the correct level on the dipstick. Would this bearing have been a sealed for life unit or is there some way of lubricating it? there doesn't seem to be a grease nipple. Do i need to fit a new bearing - is it likely to seize up?
