Witchwood
Hi, I'm considering buying a Hunter Horizon 23 and wondered if anyone could give any thoughts on a couple of potential weak spots.
1) the efficiency of the self-tacking jib arrangement. I have heard from owners of the larger 272 that it doesn't do much for the boat's speed to windward and would like to know if this is also the case with the smaller 23. Would I really need a genoa? This would involve the addition of all the necessary equipment such as cockpit winches, sheet travellers/cars and obviously a new genoa, so some extra expense to factor in.
2) the efficiency of the outboard arrangement. Being in a cockpit well on the port side, will this be an issue for manoeuvrability at low speed and will I lose drive on port tack if motor-sailing in strongish winds?
Are there any other aspects of the design I should look into?
Cheers.
Cheers.
