I have the age old problem of waterline and bow staining on the white hull of my Moody 31 ( Mk2 1988 ). Polishing out is not possible but I have tried Starbright (oxalic acid) hull cleaner which works a treat for a few weeks but the brown stain seems to return, with increasing regularity. The acid appears to 'bleach' the stain away but I am not sure if it is causing any damage to the gel coat - perhaps resulting in it being more susceptible to further staining ? I tried giving it a good polish at start of season to build up a resistant surface but it did not seem to do much good.
Has anyone found the miracle cure for this common problem or should I just pursue regular applications of the Starbright hull cleaner ?
I thought I might contact 'Moody' in Portsmouth for some advice from the manufacturer. Any comments out there ?
Hamish
Hamish
