alb40
In the spring, I will need to be thinking about sorting out a few soft spots in the hull of my boat. From the waterline upwards, she is built from plywood which is either 10 or 12mm in thickness.
Due to a few leaks in the decks under previous owners, a few spot areas have developed in the hull. I havent done anything with them yet, seen as though most of these areas are well above the waterline.
My question is... what sort of plywood should I be using? Is the standard grade Robbins Elite Plywood upto the job? or should I be using a higher grade (and even more expensive) wood? I plan to coat all the sides and end gain with epoxy prior to fitting.
Much of the wood is fixed using copper rivets. Ive never had to replace any before. Can anyone give any tips on how to use them? Or shall I just use countersunk bolts instead for ease of use?
Any other tips in this (fairly major) operation would be gratefully recieved.
Thanks, Alex
Thanks, Alex
