BahrainHobie
New Member
Hi from sunny Bahrain!
I have just started to rebuild an old Skipper 17 and have hit a problem. The hull deck joint is in a bad way, most of the fasteners have corroded away and the filler/adhesive is falling out from the edge of the joint. I can still see more filler/adhesive further up in the joint but I need to fill the void at the edge to make it stronger and water tight. Anyone know what filler/adhesive to use? I think something in a cartridge would be the easiest to use? Cheers.
