Scillypete
Remove a deceased vertical windlass? I am struggling to get the below deck motor to part company with the on deck windlass. All that seems to connect them is the stainless steel drive shaft. I have removed a rubber seal and a circlip but still it won’t drop out, I can see a bearing that the shaft passes through and there is what looks like a thick washer but that won’t shift and is not attached to the shaft as there is a visible gap when I push the motor from side to side. I have removed all the nuts from the bolts and the below deck flange has all broken away so the two are only now joined by the shaft.
help
help
