Nostrodamus
On our boat the main sheet goes through two blocks (top and bottom) behind the cockpit to give a 3:1 purchase on the mainsheet down to the traveller.
The problem I have is that the main sheet between the blocks continually twists numerous times making it harder to pull in and out.
I have untwisted the line, turned the blocks and tried almost everything but it always ends up the same.
Has anyone else encountered this and did you find a solution. I tend to think it is the natural twist in the line causing it.
