BartW
Hello, first post on here,
I’m a regular on the mobo subforum
When Our old (1991) Canados 70 mobo was build, the Canados yard (Italy) was in transitions from wood to GRP build boats.
Our’s has a GRP hull but deck, gunwale and superstructure are wood.
The deck consists of plywood on a wooden framing, with a top layer of teak (original thickness was 12mm)
But after 25y and many times sanding, the thickness is <5mm in some area’s.
5 Years ago we have recaulked the teak , and first cut out all the caulking grooves down to the plywood surface
But now more and more water leaks to the lower level are appearing (and we try to fix each time)
So it is time to renew the teak,
Next winder we want to do this work, but start now with the planning and preparation.
So far this is our plan:
First take off the old teak
Then repair potential rotten panels of plywood, and or frames,
Looking from the lower level (cabins, engine room , utility room... ) to the underside of the deck, condition is mostly OK,
but there are a few spot where some repair work is needed.
When we have a complete refurbished plywood floor (and potentially a few new frames),
I was thinking to place one or more layers of glass mat and epoxy on top, to achieve a sealed surface.
The mats can be feathered or glued upwards against the superstructure (wood) and the gunwale (GRP)
Then the new teak goes on top of this sealing.
Some people advice against this layer of glass mat / epoxy,
Because of potential moisture issues’s in the underlying plywood panels from condensation.
Another point of consideration is potential crack’s in the matting,
The hull with wooden deck can have some flexing when this heavy boat is in rough see,
Won’t this flexing cause crack’s in the glass/epoxy layer ?
What does the forum think
Is the proposed system ok?
What is the best way to seal these decks ?
thanks for opinions
cheers.
thanks for opinions
cheers.
