How to remove a frozen ditributor rotor arm in one easy step
Ballistix
12 Feb 2008
Oxfordshire
www.cinematreadwell.com
Pray Sir do tell, what is the artists tool of choice for this shattering event?
Do you advocate the chisel and lumphammer over the vice grips, a modest little flamethrower or old fashioned diamond disc-cutter ?
I have had great success by immersing the reluctant object in about 60 metres of salt water..
Two large spanners, two blocks of wood, ultimately a hack-saw and a lot of bad language. Apparently Mercruiser put them on tight to stop them coming loose...yeah right...unbelievable pain in the arse!
T
Knowing the boat that you have I want to know how you get a pinewood table in the engine bay!! /forums/images/graemlins/laugh.gif
If you hadn't mentioned what exactly the picture is, I for one would not have guessed.
A most thorough job, Sir ! Gonna fit electronic ignition now ?
Well, it is electronic, rofl...so Mercruiser say, but I know what you mean. You see the silver "toothed" wheel. That passes through an electronic gate, well actually it just cuts the power to a particular spark plug, but they call it electronic. /forums/images/graemlins/smile.gif
I can tell you it's a swine to get off, so heads up to anyone doing it!
T
