How to make a new shaft key (non boaty)
Oscarpop
31 Jul 2011
Kent
Help required please.
Have a compressor at work which has a turbine fan attached to it on a rotating shaft which provides cooling air.
The turbine has broken ( which I think that I can fix with epoxy)
However, the key which fits in the shaft ( same as a prop shaft key), has disappeared.
How do I make or aquire a new one please?
You should be able to find one OK - try Googling "Woodruff Key"to find suppliers.
I would just suggest you are very careful not to use too much epoxy as it may ruin the balance of a turbine fan.
Rob.
Woodruff key is only used if the slot is a semicircular cut unlike the normal marine shaft key which is square section brass if underwater or steel
You can buy key steel from a good engineers merchant
Just cut to approx length and file the ends as required a good fit is press or interference sides and clearance on top.
Or get a washer of suitable thickness and cut an edge off it and file to fit. They are only mild steel, the taper is supposed to give the grip to drive things
Stu
