Andrew G
I have in-boom furling which means that the 6 mm bolt rope on my main's luff (and foot) slides up a plastic extrusion at the back of the mast. The luff is 13 m and I'd rather not go up the mast (but can if I have to).
I'm trying to reduce friction hoisting and lowering the main (its a real pain). I propose to use a spray pack of silicone to spray in the extrusion - if it works I'll repeat it as required.
My question is - any suggestions as to how I might be able to turn the spray pack off/on as I pull it to the top and/or lower it down so I don't make a total mess and/or run out too soon (I'm not fussed about having to buy more than 1 can)?
(I reckon I can afix the can to a slide in the extrusion and use a short tube to direct the squirt and that I can pull the whole assemble up with the topping lift/halyard - but how to control the squirt?).
Thanks, Andrew
Thanks, Andrew
