How to identify yamaha outboard year of production
keepalex
26 Jun 2020
Can someone tell me the year of my Yamaha four-stroke outboard please? I've found various guides to decoding the serial, but mine does not seem to match. :unsure:
Photo attached, and data copied below:
F4AMH
68D L 1046411
M
Many thanks
CliveF
15 Jan 2017
I found the dealer chart in my tablet images folder. It is exactly the same as the one i gave a link to.
I am confident that is correct as it tied up perfectly with the Yam i was sourcing spares for.
They do state that the letters are recycled but that is a 23 - 24 year cycle ( they don't use at least E and O at all ) So unless you version looks like it was out of the ark ( 1983 ish ) then it has to be a 2006 / 2007 . It can not be any more recent than that as they have not made them yet.
Regards Clive
coopec
N/A
23 Nov 2013
VicS
13 Jul 2002
I knew Id seen it somewhere. Now found it See the Footnote to the Yamaha codes explanation on the iBoats website:-
Yamaha Outboard Year Help
From 1984 until 2005, the following logic was embedded in Yamaha Model numbers:
example: SX150TLRY Saltwater OX66 EFI, 150 HP, Trim & Tilt w/electric start, 20", Remote control, 2000 model.
Model DescriptionHPTilt and Trim
Starting Method
ShaftControls Methodyear*
1984-2005
B = Inshore
C = C series
D = Twin propellers
E = Enduro
F = Four stroke
L = Left hand
P = Pro
S = Saltwater
T = high thrust Four stroke
V = V max
X = OX66 EFI
Z = HPDI
2.5
4
6
8
9.9
15
20
25**
40
50
60
70
75
90
115
150
175
200
225
250
300
350
T = Power tilt
or tilt and trim
P = Power tilt with
electric start
E = Electric start
M = Manual tilt with
manual start
S = 15"
L = 20"
X = 25"
U = 30"
R = Remote control
H = Tiller handle
J = Jet drive unit
N = 1984
K = 1985
J = 1986
H = 1987
G = 1988
F = 1989
D = 1990
P = 1991
Q = 1992
R = 1993
S = 1994
T = 1995
U = 1996
V = 1997
W = 1998
X = 1999
Y = 2000
Z = 2001
A = 2002
B = 2003
C = 2004
D = 2005
*Note: Starting in April 2005 (2006 Model Year and newer) Yamaha no longer designated model years at the end of the model number identification. The production date can be found on the transom bracket of post 2004 motors.
CliveF
15 Jan 2017
It may be on the Iboats site, which is USA based , but that does not stack up against the codes in the image of the OP.
The codes I refer to are from European dealers.
Clive
VicS
13 Jul 2002
Clive
But the OP has found a sticker identifying it as 2006. According to your link that would be a code letter N , not M
CliveF
15 Jan 2017
Well blow me you are correct. The link does indeed show that.
Fortunately for me my retained copy shows N as 2005 although i was incorrect in saying they were identical.
Any way the other sticker gave the OP his year answer, which we both agree on.
regards Clive
