Graham Pearson
Hoping someone will be able to tell me how to free up my essentially seized-up rudder.
Builders info states; "bearings are grease lubricated ferro-bestos running on stainless steel bushes shrunk onto the rudder stock".
Problem is that the greasing point is a nut with a tapered round hole. There is no nipple, nor has the nipple broken off as hole (approx. 5-6 mm) is smooth (no thread). So what kind of grease gun fitting can be used to inject the grease and if there is no nipple how can you obtain the pressure to disseminate the grease in the tube?
Boat has been on the dry 3 years, could it be that lack of immersion has caused whatever seal is used to prevent water ingress into the tube to dry out or shrink thereby somehow interfering with the bearing?
Very grateful for any help offered.
