peter2407
This is a Tohatsu 3.5 with Forward/Neutral gears. I drained the gear oil last year thinking I could do the full service, but failed to do so (so many reasons). Checking the manual it says drain the gear oil via the lower plug when the O/B is upright, and to re-fill use a squeezy gadget think that I dont have via the lower plug until it flows out of the upper plug. I improvised with an icing bag and a straw, but .... the O'B is lay at a 45 degree is angle to vertical (up) and I have squeezed more than the required 180 mL no tell tale at the top. I know lots of oil is on the drive and not in the gear box, but any advice? I dont want to risk the gear box cos the O/B is usually reliable. In this position I am getting 'squeeze back' from the lower plug. How can I tell if there is/isnt enough gear oil without risking the gear box.
