simonfraser
i know it's a computer fix, but we all have laptops, some with a noisy fan, my fan came on full power every minute or so to cool the laptop down, then switched off again, very anoying, so this is what i did:
the usb port produces 5V, outer pins when you check the board
the laptop fan uses about 3.5 - 5V
pull the fan plug out of the board, check the laptop still works, some have a sensor wire and don't boot without a fan plugged in
fit a small adjustable resistor, maplin UH-23 22-turn cermet 1k, in line
switch laptop on and adjust fan speed so the pc still cools, but is not too noisy, worked a treat on mine
you can run temperature software, such as speedfan, to check it all
just to cover myself, if you blow your laptop up doing this, don't blame me, but do post it on the site so we can all see how "good" your soldering/anti-static skills are !
