jimi
Shurflo started leaking from join in base. Smothered it in plumbers mait to keep under control until I could fix. Switched off and disconnected wires unscrewed in-line filter , rats water spews out, hastily rescrew, turn tap on until pressure gone. Disconnect with no issues, spend next 90 minutes cleaning plumbers mait off pump and then another 30 mins off me. Try to dismantle but screws are corroded in, soak in wd40 try again no luck. Apply heat via soldering iron no luck. Get on internet and order replacement, put back on , friggin leak has disappeared and it all works ok!!
