How to disassemble sliding roof on princess v48
Mr. Lynggaard
New Member
12 Feb 2021
I just bought a Princess V48 2005, and I vant to disassemble the sliding roof for cleaning. The inner part is no problem, but I can not figure out how to get the top off.
Hope you can help.
Regards
Lynggaard
Denmark
I have done a couple of roofs on some of the bigger Princesses, so if its the same system you have to disconnect the wagons which run on the tracks from the roof. They have a fitting which allows you to adjust the height which you unbolt. Be careful with the cable as this can be tricky to set up if disturbed, lubricate the pulley mechanism as well as the tracks before you put it back.
If its working then leave well alone, just lubricate the pulleys. You didn’t say if its a fabric roof or a hardtop, the fabric is easier to work with.
