mjkinch1
We have been moving around marinas, and have had some fairly strong winds and/or been open to every passing wave and swell. (Bear in mind there are no tides, but around a meter or so rise and drop according to the weather, but we are on floating pontoons anyway)
Generally we stern moor, with a single line to the front (lazy line although why they call it that beats me, its pretty hard work getting it secured tight!) - usually floating pontoons. The lazy line can have a pull either left or right depending on which side cleat I use.
So on the back we put the standard ropes, and to stop me swinging about I then cross 2 ropes (springs) to stop the sideways movement. In most cases we have been in a beamier mooring than we need,so generally have had a meter either side of us between boats.
Now at anyone time there is slack in the ropes, either because we are being blown left or right, or forward etc, often one side will be tight,the other side slack.
The standard ropes from the cleats to the pontoon tend to have some slack in them, as we bounce about, and the spring ropes alternate tight and loose as we move sideways.
To try and get some stability, I tried keeping the springs tight, but in reality its quite difficult.
Whats the general opinion on how the ropes should be tied and tightened to keep movement to a minimum?
