How strong is GRP?
FlyingDutchman
15 Dec 2004
Amstelveen, the Netherlands
Most likely a stupid question from a newbee:
When working on my GRP boat underneath the floorboards (around the engine, propshaft etc.) I always try to avoid stepping on the hull itself and try to stay on the beams. My fear is, that my 75 kilo's are too much for the GRP and i am afraid to step through it!
Is this fear realistic or can you just walk around without damaging anything?
MIKE_MCKIE
5 Sep 2002
Me Hants, Boat Gosport
Do not know the boat, but with that size engine, I would hope that the hull can easily take your weight, if not you are in trouble! If you consider a boat clobbering the quay, the impact point takes the whole weight of the boat (several tons?) hopefully without fracturing, so your 75kgs should not be much of a problem, in my opinion. Just dont sue me if you do fall through!
FlyingDutchman
15 Dec 2004
I am sorry I did not mention anything about the boat.
It is a Norwegian built boat with a round stern with a length of 7,2 meters. The GRP hull looks like it is made of wooden planks. I am Dutch, so I don't know the English wording for it. The weight is around two tonnes and the engine is a 4 cylinder Volvo Penta Diesel with 59hp. Hope this makes it more clear. I do have a picture on my PC, but I don't know how to post it?
snowleopard
Oxford
if you can walk around on the bottom of a mirror dinghy which is 6mm of cheap plywood, the bottom of a GRP cruiser is no problem. nor would it be for an elephant!!! GRP is very strong. if you want to prove it to yourself, find a piece in a boatyard's waste and try hitting it with a heavy hammer - just be careful that it doesn't bounce back and hit you on the head.
i managed to get a hole in the bottom of my boat but it happened when the boatyard dropped all 6 tons of it onto one small sharp stone.
richardandtracy
27 Jun 2002
Medway, UK
Being needlessly technical & answering the question that was initially asked...
A good rough & ready answer for most polyester chopped strand matting layups is 50N/mm^2 for a long term load and 115 N/mm^2 for a short sharp load. For woven rovings you can get up to 2.5x the strength, and a breaking strength of 1200 N/mm^2 along the fibres for unidirectional epoxy laminates [ie the same strength as cap head bolts!].
As for applying this info.. Provided that the supports are at least every 600mm (2ft), a 75 kg person will not over stress a 5mm thick CSM laminate when walking over it. I have stressed a 2mm floor from sheet aluminium & found that 2x100 kg people only stress it to 150N/mm^2 at 2g with 600mm supports. The strength is proportional to the cube of the thickness, so 3mm would pobably be strong enough - but feel disconcertingly flexible.
Regards
Richard.
aitchw
18 Feb 2002
West Yorkshire, UK
And that is for flat panels. If there is anything in the layup like the simulated clinker I think was described in the original post the stiffness will be improved in that direction at least similarly with the compound curves of a round bilge hull form.
Anyway, no problems with walking around on it. I frequently stand in my GRP Albacore dinghy hull which is nominally 5mm thick whilst on it's trailer with no apparent problems.
Thistle
2 Oct 2004
Here
don't like to drill a hole just to measure it...
Plenty of holes already in the hull, I should think. A little bit of measuring next time you have the pipe off any of your skin fittings should give you the hull thickness.
