How slow do you sail ?
sailaboutvic
26 Jan 2004
Northern Europe
I'm curious at what speed under sail do people start their engine ?
On short sails under 15 miles we happy just to plod along as long as we moving forward .
We rather be sailing then rushing to get into an anchorage and sit bobbing about .
We are a Heavy boat so we need wind to get us moving at speed .
But Even on long trips and especially at night we sail at 2 kts ,unless there a reason as in weather change of at time when the waves are hitting us at an angle that the boom does nothing but slap . ( our bung we rig at times to act as a shock absorbers isn't any help )
Two weeks ago we sailed the 360 nm from Sardinia to Malta , our speed ranged as high as 7 kts and as low as 2 kts there was many hours at low speed below 4 kts but over the 360 miles we still avg around 5 kts .
It's not unusual to see people motoring pass us when they have favourable winds ,
Is it the case that sailors these days feel anything under 4 kts isn't acceptable?
Agree there times when one have too turn the donkey on .
It all depends.
On an ocean passage the engine goes on very very rarely. If we are becalmed, I just go for a swim...
Crossing the channel I’m much more likely to put the engine on when the speed drops below three of four knots because it’s a tedious trip I’ve done many times and I just want to get it over with. I also know I’ve got plenty of fuel to get there.
It all depends. If we’re heading for somewhere that get crowded and we need to get there, then we’ll motor if the speed drops below about 2.5 knots. On the other hand, if there’s no pressure to get somewhere for a particular time, we’ll just plod along unless we’re making no progress at all.
Long crossings it depends on how the foods holding up and how much fuel we’ve got: the motor goes on if we think there’s no wind to be had any time soon and the fresh food is running out...
I start thinking about the donk at anything below 2kts.
It depends on what we are doing and the motion of the boat. I hate rolling about, slatting the sails for hours on end for no gain.
With us it’s 5 knots but if we have more time then 4.
We are time limited and I’d rather have a lower speed but it’s one of the compromises I make for happy sailing as a couple.
As others it does vary and sometimes you just want to get somewhere and stop ! Quite often though, the engine is used to make 'tidal' gates such as Portland Bill, St Albans and Hurst Castle otherwise another 4 hours plus is added on to the voyage.
The basic problem is a sea bigger than the wind can push against. If you can't keep the sails full it can be purgatory.
Last year doing a circuit of Ireland, we found the westerly swell difficult to deal with if the wind was less than about 15Kts.
Otherwise under 5Kts of real wind is about our general patience limit.
I love sailing slowly and once took four hours to sail a few miles from Copenhagen to Ven a few miles away. However, if we are on passage across the North Sea with just us two oldies on board, I will put the engine on if the speed drops below six knots. If I have started at 6am for a day-sail I don't want to arrive at four in the morning. I have nothing to prove.
Sailing round the CI and normandy/Brittany coast, tidal gates for both harbour access and having a tidal stream with you rather than against you are pretty critical, so I always have an eye on missing a gate...
If that is not an issue, my cutoff is usually about 3 to 3.5. Although First Mate sometimes seems to be ‘let’s just get there’ if it gets below 4 ..
For FM it Depends on the overall weather (sunny and warm vs grey and a bit chilly)
We’ll tend to motor sail if we do start the engine, if at all possible
Six knots really or you just pulling our leg :)
I can see that - our 5 knots could easily be 6 as an arbitrary figure. The problem comes I think from doing a passage plan at a particular speed (for us 5) so my wife considers us to be running late if we drop below it. I’ve tried getting her to plan at 4 knots but she said correctly that that is too inaccurate.
We be running our engine all the time at that rate :)
To get a constant 6kts we need at less 15 kts wind and then the seas have got to play ball .
When we do long crossing we try and aim for winds over 20 kts but has I sure you know out In The med is all or nothing and to get a good wind for a 36 hour passages let alone a 72 hours is hoping too much .
The trip in the opening posting we had winds from 8 kts up to 33 kts , speeds 7.5 kts down to 3 kts and ever thing in between in the end we had nothing and had to motor the last three hours , Wind died and we was left in a couple meters seas being thrown all over the place .
I suppose we do have all the time in the world so unlike some people we can just plod alone .
But we also like not having the engine running and fuel is no longer cheap .
It was very noticeable in the Baltic how the Scandinavians were much more interested in pure sailing. Even older boats often had immaculate laminate sails, and would happily sail upwind or downwind in 5 knots of breeze.
Meanwhile most of the British ensign boats shoved on their diesels and motored all day at 6 knots.
We specifically chose a boat that would be fun and efficient to sail in under 10 knots breeze, so enjoyed mini “races” with the Scandinavian boats :). Lack of tidal gates in Baltic helps. But sometimes we change explicitly into “delivery mode”, typically to longer distances to get to a new cruising area. Then engine on certainly below 4knots SOG.
Interestingly in flat water, motor sailing doesn’t really exist with a brisk boat - if need to motor then wind so low that will in most cases need to furl jib as apparent wind goes almost directly ahead.
In crossing from the Azores to Lagos we had our own little doldrum following us along. Not enough fuel for the whole journey, so 4 hours a day on engine at 6 knots and drifting about the rest of the time.
For us, it's not really a question of speed. There are 3 reasons we start the motor:
*The mainsail is slatting badly
*We reckon motoring for a short while will get us to somewhere with some wind - typically at lunchtime moving out of the land breeze into the sea breeze
*We are coastal sailing and the wind has died in the evening and we want a viable anchorage
As slow as the conditions allow. Reasons the engine goes on:
* to get somewhere before dark (we're normally going to places we've never been before and while it's possible to do this in the dark, many places it's much better if you can see, and also more fun).
* to get out of an uncomfortable sea state sooner (e.g. light wind but big swell)
* if the wind is so light/the boat rolls so much that the sails are slatting. As Dashew correctly points out, it's cheaper to motor than to pay for the wear on sail hardware in that situation. We usually leave the main up to stabilize the boat and/or motorsail.
* for collision avoidance (today we crossed to Cephalonia and met two cargo ships with fast asleep crew and an Italian superyacht playing chicken with us - sail before power? Dream on!)
* if speed is meh and the batteries could do with some charging anyways (this is rare as we mostly have enough solar, but if there's several days of rainclouds it can happen).
* in places not suitable for sailing (like the Corinth canal).
When we're in a cruising ground, a lot of motoring can be skipped by simply waiting another day or three in the anchorage for the wind to get more favorable.
Now the next question is, how many cruisers bother with beating into the wind? :cool:
We usually put the engines on once the speed drops to 4 knots or lower. However, we usually leave the sails up as at least it's showing willing and the wind might just pick up again .... although it usually doesn't. :(
Richard
I spoke too soon. :)
After writing that post we set off heading south after leaving our long bay heading east . There was little wind so we left the bay on engines at about 5 knots boat speed but we put the mainsail up anyway. Once we left the bay and turned south we had a wind from the west right on the beam which quickly climbed to 12 or 13 knots. Genoa was raised and engines off and we sailed at around 7.5 knots for the next hour or so until we had to turn east again. With the wind now directly behind our speed dropped to 4 knots so on went the engines with just mainsail up for the last couple of hours.
All in all, a good day in the Adriatic! :encouragement:
Richard
