colhel
Thought I'd read somewhere that this is possible but never worked out how. Just curious
Thought I'd read somewhere that this is possible but never worked out how. Just curious![]()
+1.Big sea anchor is the only option.
+1.
Trouble is, an effective sea anchor good enough for a decent size mobo is a total PITA to store/handle/deploy.
I've seen a 60' steel trawler built to survive just about anything, and one of her features was a motorised drum in front of the portuguese bridge, with 150m of a very substantial nylon rope, and a dedicated bow roller.
According to the builder, it would be impossible to handle a sea anchor good enough for such boat size without that sort of equipment...
So the answer is yes, you pull the throttles back and apply autohelm![]()
If you pull the throttles back, the autohelm is next to useless.
The OP didn't mention sea or weather conditions. Heaving to can be used for anything.
For general "heave to", I would turn the boat around - arse into any weather and "hang on the props" thus letting the bow fall away down wind - you can't control it anyway.
Then using one engine at a time "crab" left and right to maintain position.
This would be the case when waiting for a lock etc
..... whilst someone else was keeping the prescribed look out of course!
By putting your stern to the heavy weather you are exposing your most vulnerable part to the risk of pooping and stove in hatches with large quantities of water introduced below. The bow is shaped to lift to oncoming seas; better that you go slowly towards the seas at and angle with the wind and seas on say the port bow and use the starboard propeller only (twin screw) or single screw to just allow you to ride over the waves. The angle of 'attack' effectively increases your time of encounter and reduces the vertical acceleration to a degree.
Then again, each to his own.
