How much will it cost Waste Holding Tank
Newbroom
26 May 2004
Woking
How much do you think I should budget to fit a waste holding tank to a Fairline Turbo 36. I would prefer to have the options to pump out at a shore station or at sea and to be able to use the toilets directly at sea without using the tanks.
And any recommendations for someone to carry out the necessary work.
Thanks in advance
It's a bit of a piece of string question, as there are so many variable, but I would suggest around £2k.
Bit too open ended really.
I assume two heads? What size tank? Custom fit (Tek tanks) or off the shelf tank? How long are the pipe runs from the heads to the tank?
You'll need to budget for a flow diverter valve to switch between tank or sea outlet. You'll need a deck fitting for pump out and a vent fitting and hose.
Lots to consider.
Had new manual loo, tank and diverter valve fitted to service rear WC on 35' Broom. Including deck fittings came to about £2400. But we had seacock already in place from previous owners old WC so that needs to be factored in if not in place. I would assume though that Turbo 36 has this already.
