Greenheart
My launching trolley is low-tech, but has given solid service for eight years, and was far from new when I acquired it.
The steel bar that acts as an axle is 35mm thick, but the outside 100mm at each end are 25mm, to fit the holes in the wheels. The thickness of the central section has holes drilled through it, to bolt it to the wood cross-member that supports the boat. The trolley is upside down in the photo below.
The bar is severely corroded and I want to replace it. The wheels barely turn because the rust is so bad.
I would much prefer to pay for a 25mm bar, than a 35mm bar with custom-milled/machined narrower ends to carry the wheels...
...but if I drill 8mm holes through a 25mm bar to attach it to the timber cross-member, how much strength will it lose?
Are 8mm bolts strong enough? Could I get away with a higher number of 6mm, perhaps?
Is there a practical alternative way to secure a 25mm steel bar to a 60mm thick piece of hardwood, other than by drilling?
And am I right, thinking that a 25mm bar will be easily strong enough (and remain straight) to carry a 160kg boat?
Thanks!
Thanks!
