D
Deleted User YDKXO
I've got an estimate for plumbing in a holding tank system on a 53ft Ferretti which I think is extremely over the top. Considering that the grp tank itself is already moulded into the bilges, all that needs doing is to fit a macerator pump with thru hull outlet, plumb in diverter valves and pipework for 2 heads only, fit a level sensor and wire it all into pre-prepared switches and indicator lights on the electrical control panel. What do you think that should cost?
