How much oil??
mlines
31 Aug 2009
Finchampstead, Wokingham, Berks
www.sportsboat.org.uk
A couple of questions.
The boat is a 2008 Regal 2250 with a 5.7 Litre 350 MAG and Bravo 3 sterndrive.
1. The manual states the engine hold 5 litres of oil. I have attached a pump and extracted 3 litres. I have never pumped oil from a V8 before as our previous boat had a 3.0 Mercruiser. With the old Mercruiser we inserted a "catheter" oil pipe down the dipstick and could pump and effectively hoover out the sump. With the V8 the pump pipe fits onto the top of the dipstick and uses the dipstick tube as the extractor pipe so I am not sure whether this gets right into the sump?? How much oil should I be able to get out. The 5 litre statistic includes the filter and I did not get the filter off yet so I am not sure how much is in the filter. Unfortunately I did not dip the engine before I started to see how much was in there.
2. I went to grease the sterndrive and on my old Alpha drive there was a grease nipple on the side of the transom fitting that greased through to the bearing. There appears to be a similar nipple on the Bravo but it does not look 100% like a nipple as it appears to have some sort of thread on the outside but no clear hole in the middle (I tried poking it) it also would not pump in grease (it just squeezed out the sides). Any ideas on this?
Martin
Just noticed from reading all the technical sheets that the later V8 (post 2002) only have a 4.2 litre sump which is closed to the 3 litres I managed to pull out so perhaps its not all bad. I also note that the manual states that "some oil" will remain in the pan when using this method and that this is ok. So perhaps I am worrying too much.
