jac
I have a 2002 2.5hp Tohatsu that is starting to annoy me. Used fine for 2 years - then laid up for a while. An expensive overhaul last year, fully serviced about March - worked and started 1st pull. Now - brand new fuel - nice looking spark - fuel on the end of the spark plug - no starting. Will fit new spark plug and try that but the existing one has done maybe 10 minutes.
My pattern of use is probably not ideal - we use club launch to get to and from boat so the tender & OB only really get used on an annual cruise or on occasional weekend. The rest of the time it sits on the bracket on the stern. I service it about the time that the boat is out of the water so it sits in the garage over the winter with fuel drained and gets treated to new fuel and sparkplug & gear oil etc about Easter
I'm thinking of replacing it with something say 3.5-4hp but 4 stroke but if it's going to be as much of an issue to keep running as this one then may not be worth the bother. SO - are modern small 4t engines better able to cope with infrequent use and be reliable enough to trust? Any particular engines that people would recommend?
