nigelmercier
RIP
- Joined
- 20 Jun 2007
- Messages
- 16,234
- Location
- Live in Kent, boat in Canary Islands
I've had a couple of enquiries about my Livol D60 Watermaker. I really have no idea how much to ask for it, perhaps you chaps could give me a ball-park figure that is fair to both parties.
The boat was built in 2000, and the Livol was fitted a couple of years later, not sure of the exact date. It was used only when the boat was in Menorca, which was for about two years. Since then the Livol has been pickled, and the pump was last tested about a year ago. Obviously I can’t test the unit without having to go through this process again, but it was working fine when last used.
Livol no longer manufacture these units, but I have found a company that have taken over the spare part supply: http://www.slce.net/index_gb.php
As you can see from the pictures below, there is a lot of kit that you need in addition to the watermaker itself, all will be included with the exception of the sea-cocks. There is some surface corrosion on a few of the valves, but otherwise it is all pretty clean. The output is 60 litres (13 UK gallons) / hour, 1440 litres (315 gallons) / day.
Info here: http://mercier.org.uk/temp/Livol.pdf
User manual here: http://mercier.org.uk/temp/D60 Compact.pdf
