cjepearson
I have to fit a new locking nut to my prop shaft to secure my new, expensive feathering prop. The snag is that the boss of the new prop overlaps the hole for the split pin, so I may have to use Loctite to hold the nut on. Is this a jolly good idea? Would it be man enough for the job? I could get an engineering workshop to "castle" the nut, but it would means drilling a new hole in the shaft (having removed the rudder to remove the shaft) Ditto for fitting a grub screw. Loctite would be a whole lot easier.
