chal
I've posted several fuel line questions lately so apologies for being repetitive. Anyway, to recap, I recently replaced an old fuel tank with bottom fuel line attachment point to a new one with a syphon and have had endless problems with air getting into it. After various attempts to solve the problem, I have now reached a point where there is an unbroken line from tank to filter and the line is translucent (proper fuel line expensively sourced in USA) so I can see what is going on.
There are no little bubbles in the line to show a leak at the filter connection, nor can I find any trace of fuel to indicate a leak anywhere in the line between the tank and the HP pump. Nonetheless, there is now an air bubble in the line, about 3 or 4 cm long; it's naturally at the highest point, ie where it connects to the tank. It's a sailing boat so we don't generally run the engine all that long, but the bubble seems to get bigger quite slowly and not make any difference to how the engine runs.
Is this something I should worry about, or something that would tend to accumulate over time that I simply wouldn't see if I had stuck to black fuel line?
