how many miles wiht Fairline?
DutchDan
13 Feb 2005
Nederland
How many miles, what distance can you go with a Fairline targa 33, two diesel engines 200 hp. cruising speed 20 knots?
kind regards
Dan
Making some fairly big assumptions:
AD41's at cruise consume maybe 33LitresPerHour each.
450L tank / 66 lph gives you 6.8 hrs cruising.
At 20kts, thats 136miles.
Deduct your reserve to get the range:
Allowing 10% reserve - 122miles
Allowing 20% reserve - 109miles
Answer: about 110miles.
dv.
Hmm. Your asumption gets you 10 miles further than mine!! Not bad really I suppose.
I have same engines, bigger boat. 150 gallons fuel 600 ltr??
I dont like pushing it passed 100 miles, maybe 130 if I have to. Theres not alot of Texico stations out there!!
tx. I wasn't sure how big the fuel tank of my fairline targa 33 is. I just read that it's about 135 gallon, so that's not so bad. I need to go from Corisca toSaint Tropez, that's about a 100 miles.
I dont think you should do this trip.....
DutchDan, if your range is really only 110miles is you need to be very careful Corsica-St Trp. I did this 10 days ago. The seas can be big, winds strong and flukey, and in a 33 foot boat you could spend some time at near displacement speed working your way over waves and swell. Personally I'd want 200miles nominal range, to cope with the extra fuel burn caused by a heavy sea. I certainly wouldn't do it in a boat with 110nm nominal range
If you decide to do it, you'll need to refuel and set off from the very top, Cap Corse. Also I think you should head north, say to Antibes. This will be a bit shorter than St Trop and also avoid you heading so much into the prevailing westerlies (which will burn even more fuel).
Re: I dont think you should do this trip.....
I once reaconed on a long trip, that my boat, same engines, but 8 tons,35ft plus. Did 1.3 MPG But course I would not risk this, so reakon 1 mile to gallon, then some spare, hence 100-130 miles on 150 gallons.
thanks for your reactions. I'm not sure about the fuel tank. yesterday i read that it's a 150 gallon, not 100. I will ask Fairline. Further on my boat is 5.5 tons. I'm going in august, so and will only go when the forecast is good!
i'll think about it.
thank you very much
I have a Fairline Targa 33 with twin 41's. Fuel consumption is 12gph for both engines at 20/22 knots. They have a 110 gal tank so if you say 150 mile range that will leave a safe reserve. But if you cruise at 28 knots they burn about 18 gph
I called Fairline, the told me that the Targa 33 has a 613 liter tank. how many liter makes a gallon?
Dan
Re: Try Again
Now that your tank just gained an extra 160L:
AD41's at cruise: 33 lph each.
613L tank / 66 lph gives you 9.3 hrs cruising.
At 20kts, thats 186miles.
Allowing 20% reserve:
Answer = about 150miles ??
Re: Try Again
I may be being a wus, but I think this is awfully tight fuel-wise for that particular bit of sea, and I would definitely head for the closest bit of the French coast, not St Tropez. Needs an excellent weather window too. Any technical or weahter problem could increase fuel consumption enough to make this very tight on fuel
I'd even consider a few plastic jerry cans lashed to the bathing platform, and a transfer pump, to give an extra 50miles nominal range
Re: Try Again
but when i won't be able to cruise 20knts but slower, then I'll use less diesel?
maybe i'll buy a jerrycan for safety. It's the first time that we'll go a distance like this with no land in sight.
Re: Try Again
If you can't plane, you'll have to drop right down to a very slow displacement speed to maintain any kind of economy. In choppy weather, this won't be comfortable, and of course, your journey time could easily triple... agree that jerrycans strapped to the bathing platform (hope theres no teak) could be a good move.
as per jfm, I would want a really solid weather forecast before even thinking about it...
dv.
