Frankie-H
Once a year at the end of the season - oil & filter
+1
Whether it needs it or not
Furthermore, road engines do not pull constantly against load whereas a boat engine is effectively a car driving in low gear with the handbrake fully on, this will heat the oil quickly and wear it out faster.
I've heard that you should rev your engine to max or thereabouts every hour rather than leaving it chugging at half revs all day.I always understood that diesel engines *like* being run steadily against a load.
The issue for boat engines is that they're often run just to get in or out of the marina, hence never have time to warm up and spread the oil. I'm certainly guilty of this - I often use the engine just to pull myself backwards out of my berth and round the end of the pontoon into the river, then immediately hoist sail and kill the engine before I've travelled 20 yards.
I think this is a simple one really. Do what the manual says. It usually says every X hours and at least once a year. In our case, Yanmanr 4JH2E, it says ever 100 hours or once a year. So for normal weekend warrior stuff we do it every winter and when we were long distance cruising every 100 hours.
Depends on your engine but as a rule of thumb 50 hours or at the begining of the season. Dont change at the end your oil is likely to get conensation in and you dont want to go all through a season with even a little water in your engine.
This is bad advice.
Please DO change the oil at the end of the season and leave the engine with fresh oil in it over the winter. Diesel fuel contains sulpher and there is a build up of acidic sulpher combustion by-products in the sump over time. Get these nasties out of the engine.
There is no reason to expect any unusal condensation just because you have changed the oil.
I am happy changing my oil once a year EVEN though my hours may ony be 20 pa.Why because my engine runs are often short and low rpm. Just enough to get the anchor up and clear the anchorage. This means that my engine oil rarely gets up to normal operating temp. for any length of time.
A good run at 2/3rds throttle for an hour helps. I say this to myself wishing I could turn the noisy thing off.
But if my hours were 200 pa I would still change once a year.
Mine's has usually all leaked out well before then, so I have continuous oil changes...
This is bad advice.
I have been told that it's recommend to change your oil every 50 hrs of motoring. Is this a little pedantic? Would 100hrs be more reasonable?
I have probably done 30 hours of motoring since the last service and the oil is still a lovely golden colour.
Engine: yanmar 1gm10
Lustyd , oil does break down, especially in an engine with all sorts to contaminate it! yes it does go off, usually goes acidic with the bonus of added extras!
