How many Amps in 8 AWG ??
Ecosse120
22 Dec 2005
Muddy Essex
I have purchased an electric winch for my lifting keel and yep the leads are to short. I am looking for longer cable and am confused by how many amps I can put through a cable I found in a motor accessory shop (cheaper than a swindler) that rates at 8 AWG ?? Looking on the net it seems to vary from 40 amp to 100 amp. As I want to put 70amp through it I am obviously concerned.
Any help much appreciated
If you're not using marine quality cable, be prepared to replace it......all the auto cable on my boat went black (corrosion) and in the end almost nothing worked.
Thank you Topcat 47, that reminded me to go and look in my Merlin catagogue and guess what a nice table saying that 8 AWG = 68amps inside and 80 amps outside.
Can I suggest that you play it safe and go one size thicker with tinned wire? That way it won't go black and heat up after a couple of seasons or get warm between winch and battery, especially as your battery is likely to be under the cockpit, and the winch below the mast - a long wire with a large current.
Or you could use a trailer winch like I do!
Adam
The amp rating of a wire relating to it's size is only concerned with the heating of the wire and subsequent dissipation of the heat. So too much current wire gets hot like a fuse and plastic coating melts and lets the smoke out. (needs smoke inside to work) (joke) So if it is outside then higher current rating. If it is in a bundle lower current rating. (continuous current long term)
Your main concern is the size of cable you need because the smaller cable gives a greater volt drop. The longer the cable the greater the volt drop. In your case for a winch you will need a cable far bigger than that dictated by max current rating.
Guessing at a return run of 20 metres you may loose several volts with 8 gauge cable. olewill
Taking the figures from the West Marine catalogue:-
"8AWG -
Nominal OD, 5/16" -
Weight per 1000', 86# -
Cir. Mil. Area, 16,800 -
Square mm, 8.37 -
Ohms per 1000', 0.62 -
Max Amps, 80 -
SAE wire sizes are 6% - 12% smaller.
Maximum current is 15% less in engine spaces.
If 3 wires are bundles, reduce max amp by 30%.
Voltage drop = Current x length x Ohms per foot."
Going by the West Marine guide, if the round circuit is about 30ft, and 80amps is required with a 10% drop in voltage, then the cable is just over the top end of 8AWG and should be 6AWG, which gives a max amp of 120. If you are looking at a 3% drop, then you would require 1AWG / 245amps max.
As a guide price for 2 core, in US$, 6AWG is $7.59 per foot, and 8AWG is $4.24
1AWG is battery cable at $6.99 per foot per single cable!!
All the above extracted from page 552 of the West Marine catalogue. This is "proper" (tinned copper coated) marine cable.
Precisely what I used for my anchor windlass. Batteries are near the engine and the cable runs forward and then back, a total return path of around 14 metres.
