Mike2309
ha ! you haven't been on one of Her Maj's best doing an emergency turn
Lookit this D skidding round and leaning out. That's what I call a mobo.
Helm turns prop (outboard) or rudder (inboard) outwards causing imbalance of water/hull forces thus rotating the hull methinks
The same way that motorbikes do, oodles of grip from the propulsion system.
Im not a mobo owner but I suspect that if you pulled the kill cord during a hard turn in a planing boat, it would drop of the plane, bite the water and she could barrel roll outwards because of the above
In order to turn the hull must develop a sideways force. It does this by putting itself at an angle to the local water flow under the hull. Planing boats have vee hulls. The sideways skidding causes the side of the boat on the outside of the turn to develop more 'lift' than that on the inside of the turn, so the boat 'banks' inwards. It's exactly the same effect as that given by dihedral on an aircraft wing.
