Hunter34
I have just fitted a new fuel injection pump and injectors to my Perkins 4 - 108 which seems to run fine but only revs to 2900rpm max.
Under load when motoring in flat calm it revs to 2800rpm.
I have checked the throttle lever on the pump and it is open all the way to the pre set stop.
Obviously the max speed setting on the pump cant be adjusted as it has a seal on it.
How much should a 4 - 108 rev to?
It is a hydraulically governed pump so I wonder if something else could be limiting the rpm.
Any info much appreciated.
Andrew
Andrew
