DangerousPirate
Todays adventure was to get the boat ready for reefing. I am single-handed, so I installed (or tried to install) a single line reefing system. The boom lacks in-boom reefing systems, so everything is done on the outside with blocks. There is a bowline tied to the booms end, a reefing line ran through the eye of the sail and down to a block mounted a little aft of the eye (instead of directly beneath it), ran the line through two eyes on the boom, a jam cleat, down to another eye a few cm above deck level, then back to the cockpit to the rope clutch. It makes a kicker-esque bend downwards because I miss a block, and didn't have one on the boat, to keep the line parallel until it comes to the mast.
I would like to run the reefing line through the second eye, to replace the cunningham as in the diagram, but for now it should do okay.
Didn't get around to test it yet. But I have two worries:
First: That there is not enough downwards pull to get good sailshape. Traditionally, you have the reefing line tied around the boom and then through the reefing eye, to a block at the end of the boom, and from there you take it forward. But since I don't have a boom that allows this, I had to rethink my approach. As mentioned above, I used a block further to the end of the boom so when I pull the line, it creates a very flat sail and depowers it. Nothing has you lose control more than a baggy main in high winds condition. It just makes everything more difficult. Perhaps two blocks at the end of the boom with the reefing line tied around the boom would have the same result as the in-boom reefing method. Not sure if mine is a good idea or if I didn't think of an obvious flaw
The second: The pre-existing jam cleats on the side of the boom are in the way and create friction in the system, when I pull from the cockpit. It may be difficult to imagine without a picture, but the rope does not fit through the jam cleat. I used random ropes I found and it's all just very temporary. So I may end up de-mounting the jam cleats all together, which obviously were installed to reef on the boom. There also is a small cleat to cleat off. Not going to use that, since it's all coming back to the cockpit now. The worry is that the high friction will make it too difficult to pull the line and reef and planned.
