skyflyer
probably depends on the make, but this much I know about my Stowe unit and I think Raymarine ST50 work in a similar way
12v gets sent up to the masthead transducer where there are three potentiometers offset by 120 degrees. The voltage down each of the three lines (green, white, yellow) will vary between 0v and 12v (less line losses) depending on the angle of the wind vane.
The relationship of the three voltages allows you to mathematically calculate the wind angle -but i don't think that is how the instrument does it because....
when you measure the voltage down the green, yellow or white line, by disconnecting it from the instrument you get a 'sensible' reading, as above, between 12v and 0v.
But if you read the voltage when the wire is still connected to the instrument then the three voltages are very very close to being the same, e.g. 4.6, 4.9, 4.3v.
Can any electronic genius explain what is happening inside the instrument? I don't need to know, I'm just curious!
