garethdeb
New Member
Hi folks
I have just bought a cheap little 14ft Marina speedboat for a bit of fun on the Solent. I'm fitting her out with bilge pump, kill switch and a few other Ought to Have's and generally tidying her up but I can't suss out how the log is supposed to work. It consists of a trailing arm arrangement on a bracket screwed towards the bottom of the transom with a clear plastic flexible tube running through the transom and all the way up to the speedo which it plugs into the back of. I can't however see how it's suposed to work. There is a reasonably stiff sprung plunger in the bracket but the tube is pushed onto the trailing arm so I can't see how the arm lifting up could put pressure into the tube, which is how I assume it's supposed to work. Can anyone tell me?
Many thanks for any help and advice.
Regards
Gareth
Regards
Gareth
