How does a steering wheel locking nut work?
Loch Linnhe
19 Nov 2011
Loch Linhhe, Scotland
The locking nut in the centre of the steering wheel on my Beneteau 411 has stopped working, and I am struggling to understand just how it works, so I can fix it, its just a knurled nut that you tighten by hand to lock the wheel, can anyone help please?
It pushes on a bronze band that acts as a brake shoe on the shaft. Take the nut off, then the wheel, clean with petrol or similar so that there is no lube on it and away you go.
Stu
Thought I had a drawing that showed it but don't know where I filed it. From what I recall, when you tighten the locking wheel it applies pressure on a simple clutch disc mechanism and locks the wheel to the wheel shaft housing using a clamping action. I have been told that you can get corrosion in there that stops it clamping up property.
Take the nut off...
OK, how about this one?
WheelBoss_zps430138de.png~original
