How do you measure the weight of sailcloth
Finbar
26 Mar 2006
Dublin
I have just bought a secondhand storm jib from Exchange Sails. Good value, not new but shape ok and the right size for my 36 ft boat (about 9 sq m).
However it seems a little on the light side to me for 30 to 40 knots of wind, which is what it is for. It was described as 10 oz Dacron when I bought it. This means it should weigh 10 oz per sq yd. However as it is a made up sail, I am not sure how to check this. The bagged sail weighs about 160 oz, but this includes bolt ropes, leech line, hanks etc.
9 sq m is about 9.7 sq yds which should weigh 97 oz, which may be ok. 10 oz Dacron would be well up to spec for a storm jib of this size.
Is there any other way to check cloth weight, such as thickness, or thickness folded a few times.?
Perhaps I am being fussy, but if the storm jib is needed I would like to be happy it is up to the job.
Not sure this will be of help: ;)
I've seen three different ounces in use, not to mention oz per sqm, sq yard, or per sq feet. So 10 oz means nothing to me :p But also I've seen 5 oz dacron storm sail working in F11, no worries. This is area versus strength of canvas, dacron is strong, area small. Just let's hope stitching holds.
You could always measure out and cut a 3ft x 3ft sq from the sail and weigh it. Actually thinking about it, probably best not to.
