How do I remove pencil anode remains from the bronze nut?
vas
21 Jun 2011
Volos-Athens
hello all,
title says it all really!
I've got IVECOs which use 12mm dia (10mm on the nut side) anodes around 40mm long.
Can get them cheap (as in 3euro a piece iirc) from a fabricator in Athens, but I've got lots of nuts with leftovers that are a bitch to remove.
Am I missing something (other than buying new anodes on nuts!) is there an easy way to remove/dissolve/whatever the old zinc anodes?
Tried a bench drill, made a mess out of it as it went eversoslightly off centre and scrapped the nut.
I'd probably do a nice job on a lathe, but I doubt the forum manmath masters could help me justify a lathe for turning 4 anodes a year...
(of course I can always go to Vangellis my machinist for it, but he'll have me waiting for a couple of months to do such a silly thing!)
any ideas?
cheers
V.
Ive made some moulds for anodes out of aluminium for a guy producing anodes. Point being the melting temperature must be lower than ali which is quite low. I don't know the melting temperature of bronze, i guess your nuts are ali bronze.
Try a blow torch?
Try a blow torch?
Could you drill a tiny hole and wind a self tapper into it?
nice ideas!
thanks gents, will try them out
Will probably end up with a combo, self taper on the zinc, plus heat to ease the thing out as I doubt a self taper, a vice and a hammer will do the trick ;)
cheers
V.
Vas, I had to drill one of the pencil anodes out on Rafiki. Not hard, just needs a pillar drill. The bronze cap nut was then perfectly usable for the replacement anode.
I changed the pencil anode in the seawater air heat e changer in the geny recently.
Just like a car rad a top hose and bottom with the pencil at the bottom too .
It too was down to the nut level .
The HCL est 33 % I pumped through for 10 mins to acid flush cleaned out the remains of the zinc in the bolt .
Paid €22 for a complete new one ,bolt with zinc 3cm x 10 mm dia -est ? allready fitted , it’s actually a Onan part or the package was
The worry of buying a zinc rod ,cutting a piece off and then stuffing into your old bolt ,is it may come out as it dissolves and then move around the system ,potentially leading to further issues .
thanks guys!
3 caps cleaned on a small pot with 33% HCL (the one for swimming pools) . Lots of fizzing, getting slightly hot, and half an hour later all anode was gone, leaving an nice and clean nut.
cheers
V.
hello all,
any ideas?
cheers
V.
I drill mine out .5mm under size & press new anode in
