Take a length of coax cable. Connect one end to the VHF set through a suitable connector. At the other end of the coax strip the outer plastic cover off for a length of 825mm. Push the mesh from the end back towards the 825mm point, This will expand its diameter.
pick the inner through the mesh at the 825mm piont. When all of the insulated centre core is extracted fully from the mesh you effectively have a dipole antenna, with the feed point at the 825mm point. Stretch out the mesh and check that both the external insulated core are both 825mm long, cut down to length if necessary and tape the split point together. Connect a tiewrap to both ends and hoist the antenna vertical, clear if the mast, with the tip of the insulated inner to the top and the free end of the braid to the bottom. It will perform better if the coax is led horizontal for a minimum distance of 825mm. It sounds quite long winded but all that is required is a length of coax, two tiewraps and a haliard to hoist it with.
