How do I fit additional cleats to aluminium mast
Jcorstorphine
19 Aug 2001
Scotland
Years ago, I built two masts from kits supplied by “Bowman Boats” for a ketch I was building. In the kit were 6 mm and 8 mm threaded Aluminum inserts which expanded when the machine screws were driven into them. The were a bit like metallic Rawlplugs.
Does anyone know where I can buy these fixtures as I want to fit some additional cleats to my mast.
KenMcCulloch
22 Apr 2007
Edinburgh, Scotland
They are called rivet nuts or rivnuts, google these words. If you use S/S ones you should also use some duralac or equivalent to prolong the corrosion-free life of the joint.
Jcorstorphine
19 Aug 2001
Scotland
Aluminium fixtures.
Belated thanks, forgot my manners!
The fixtures I was supplied with 35 years ago were more like split collets which widened when the machine screw was driven in and I was never very happy with them. The Rivnuts you suggested look much more robust.
Regards
jc
vyv_cox
France, sailing Aegean Sea.
coxeng.co.uk
Rivnuts are excellent but you need to experiment a little with the setting in the thickness of metal in which they are being inserted. It is all to easy to set the shank into the gun too far so that massive force is exerted to get the thing to close, or alternatively to set it too loose so that it turns when the bolt is screwed in.
William_H
28 Jul 2003
West Australia
Cleats ona a mast
It seems to me that plastic cleats attached by metal thread screws into a hole tapped into the aluminium mast is very adequate. Just use Duralac as said. A metal thread tap is fairly cheap and very useful.
good luck olewill
Scotty_Tradewind
31 Oct 2005
Me: South Oxfordshire. Boat, Galicia NW Spain
that's intersting William, although if done well into a good thickness the thread would hold, but wouldn't the Duralac be removed from most of the thread when screwed up and so the barrier it provides between the two dissimilar metals is more likely to be lost?
If using s/s cleats on an alloy mast its also a good idea to put a barrier between the two. I tape mine with gaffer then usually monel rivet them if the gun can be got into position. With a sharp blade the extra gaffer can then be peeled away.
rogerthebodger
3 Nov 2001
good luck olewill
That's how I did mine. I also fitted pad eyes for my reefing blocks that way.
IMHO Duralac is only needed if you wish to remove the cleats at a later date.
William_H
28 Jul 2003
West Australia
Duralac
Yes it is needed on all SS screws or rivets into Ali and no I don't think the duralac is lost when you screw the screw in. Rivets are OK for cleats if you can find them long enough. olewill
john_morris_uk
3 Jul 2002
At sea somewhere.
Another solution is to rivet the cleats to the mast - at least that is how my mast was built. I had to replace a (missing) cleat a few years ago, and the rigger sold me the correct length monel rivets etc to put the new cleat on. Admittedly its only used for the lazy jacks, but its remarkably strong for what it is.
